Gaea 2 - How to create a 3km x 6km rectangular terrain?
Hi everyone,
I want to create a rectangular terrain of **3km x 6km** (18 km²) in Gaea 2 for a Unreal Engine 5 project.
I tried setting Width: 6000 and Height: 3000 in Terrain Definition, but it keeps building as square (4x4 tiles) or not applying correctly.
Questions:
1. What is the correct way to set a non-square (rectangular) terrain in Gaea 2?
2. Any tips for performance and best workflow?
Thank you in advance!
Hey,
In Gaea 2 there isn’t directly,
However you can still use the space to create your rectangular area within and set the rest of the unneeded sections to the floor/mask away, kind like only using part of a canvas
It’ll still export square but you could make a second pass to remove it in other tooling software, if needed.
Alternatively you could make it rectangular, export it stretched to a square, and in your renderer transform it back to rectangular.
Either should be possible.
Hope that helps
Thank you very much. You’ve been very helpful. I’ll remove the excess parts. Have a good day.
