spherical planets in gaea 2.4/gaea 3
Now that Gaea’s getting tools for building larger-scale worlds, I was wondering whether it would be possible to create spherical worlds in Gaea (as a 2D projection of a 3D sphere, of course), and whether this could be done without distortion? For example, there’s a tiling method using hexagons and pentagons that can form a sphere without any noticeable distortion.
Would hexagonal and pentagonal tiling, as an alternative option to square tiling, be a possibility? Or is there some other method that would allow Gaea to produce spherical worlds? I’d be very interested to know if something like this is being considered.
Gaea is typically square because GPUs love it hence many who do hex or spherical work just mask/remove the unwanted parts.
Gaea has had /hemisphere node for some time now ideally you would work two projects for each.
Sadly this doesn’t solve all needs but
Gaea can build up to 256k resolution, for a 1m/px scale that’s 65,536 km² or more of course if you start using 2 m/px or 5m/px if a project allows
I have made a Blender plugin to help with this workflow. The Reddit post has images and a description :blush:
https://www.reddit.com/r/mapmaking/s/4JHFMKP451
