Gaea Docs Update
Documentation has been something that, frankly, we have struggled with since 1.0.
As our team has grown, we are now approaching documentation differently. We recently started publishing new content on both the video and manual fronts.
We revised the documentation heavily and are going through and fixing the gaps and missing bits. As of this writing, the documentation stands at around 100K words, spanning over 450+ pages.
At the same time, we have been regularly releasing new in-depth videos covering individual nodes on our YouTube channel - and are updating the documentation on individual nodes as well.
Next up we will be adding a new Guides section that goes beyond the core technical manual and cover specific tasks, larger strategies, and application-centric articles.
Subscribe to this post to stay updated. We will post new information whenever there is a significant update to the documentation.
We’ve added a Documentation Changelog in the Release History section. This page contains a granular list of all pages as they’re updated.
In preparation for the upcoming Gaea 2.3 Bleeding Edge build with Macro support, we’ve updated the Macro documentation.
In addition to basic building instructions, there is a page dedicated to best practices for creating and maintaining macros.
March Docs Update
[!NOTE] Note
This is a March docs update,
Some newer documentation work is still being prepared, so April updates will be posted separately soon.
We have been doing a pretty large cleanup, expansion pass and technicals and user guide upgrade across the Gaea 2 docs so they are easier to search, easier to follow, learn and closer to the current Gaea 2.x experience.
With over 300 page updates to bring it more together. Full docs changelog is here: Documentation Changelog[1]
Node Reference updates
A large pass was made across the Node Reference to bring pages closer to current Gaea 2.3 behavior and fill in missing information/properties on nodes
Highlights:
  • Updated many node descriptions and metadata
  • Added missing node information where available
  • Added/updated various nodes like ColorThreshold documentation
  • Cleaned up outdated or removed node references that had gone stale
  • Improved consistency across node categories like Modify, Simulate, Utility, Output, and Derive
Useful starting point: Node map[2]
Install, licensing, and setup docs
We also updated several setup-related areas so new users and studio users have a clearer path.
Updated areas include:
  • Getting Started
  • Install Gaea
  • System Requirements
  • Regular Installation
  • Uninstall / Clean Install
  • License Management
  • Fortress Server
  • Gaea 1 migration / node changes
Examples:
  • System Requirements:[3]
  • Install Gaea:[4]
Build, export, and regions
The build/export area received another round of cleanup, especially around larger terrain workflows.
  • Build Options
  • Regions
  • Tiled Builds
  • Build Reports
  • Build Path Tokens
  • Profiles and batch builds
  • Exporting nodes and mesh exports
Build Options:[5]
Regions:[6]
Macros, automation, and developer docs
The developer-facing docs were expanded and reorganised in a few places.
Notable updates:
  • Building Macros received new screenshots and clearer steps
  • Macro import/export information was improved
  • Automation and CLI sections were cleaned up
  • Bridge-building docs were refreshed
  • Expressions, variables, and Math node documentation received updates
Building Macros:[7]
Automation:[8]
Videos and learning resources
The video section had a big organisation pass.
This includes:
  • More official tutorial pages
  • More node-specific video links
  • More community videos
  • Better video indexing so related learning material is easier to find
  • Better Showcasing for Authorised Partner videos
Videos:[9]
Site cleanup and search improvements
Some of the less visible work should still make the docs feel better day to day.
We worked on:
  • Page descriptions and metadata
  • Search text cleanup
  • Table of contents regeneration
  • Image recovery and heading cleanup
  • Internal link/report cleanup
Basically: fewer dead ends, cleaner pages, and better search results.
What is next
April documentation work is already way underway and will get its own update once it is ready/live.
Expect more cleanup around:
  • Node Reference pages for useage goals
  • More comparison images for nodes
  • better index pages for catagories
  • More official video links
  • Examples and workflow pages
  • Consistency checks with newer features
Thanks for bearing with the dust while the docs keep getting cleaned up.
:saluting_face:
  1. ↩︎
  2. ↩︎
  3. ↩︎
  4. ↩︎
  5. ↩︎
  6. ↩︎
  7. ↩︎
  8. ↩︎
  9. ↩︎
April Docs Update
[!done] Live
[!Note]
This is an April docs update.
  • A few April documentation items and newer feature pages did not make this roundup, so follow-up updates will be made separately.
  • There is process lag between doc updates, topic updates and the live docs updates, please bare with if you don’t see the live updates right away or older links.
April was another large documentation pass across the Gaea 2 docs, focused on bringing more of the current 2.x workflow into the docs, tightening navigation between related pages, and filling in missing reference coverage. New and existing users should have a greater navigation experience across the docs on PC and Mobile.
This round covered 265 page updates. Full docs changelog is here: Documentation Changelog[1]
At a glance
Area Updated pages Notes
Node Reference 196 Large pass across node categories plus Node Map coverage
Release History 19 Backfilled and cleaned up version history pages
User Interface 12 Build Options and graph workflow pages
Using Gaea 11 Build/export, graph management, terrain import, and surface workflow docs
Developers 9 Extensibility, automation, expressions, CLI, bridges, and macros
Guides, Install, Videos 17 Setup, Unreal guidance, troubleshooting, and official learning pages
Node Reference expansion
The largest part of the April work was another heavy pass on the Node Reference.
This included broad updates across:
Category Updated pages
Modify 42
Simulate 26
Primitive 24
Surface 22
Utility 21
Derive 15
Terrain 15
Colorize 14
Output 13
which introduced better landing pages, navigations, syncs with published videos and cleaned up properties and visual usage.
Useful starting points:
  • Node Map[2]
  • Node Reference[3]
Developer and extensibility docs
April also included a useful developer-docs cleanup, especially around extensibility and automation.
  • Extensibility overview cleanup so it is easier to choose between macros, variables, expressions, Math node workflows, and future SDK planning
  • Building Macros improvements with a more structured authoring flow, clearer export guidance, and better parameter exposure steps
  • Expressions and Allowed Functions cleanup for scripting-oriented workflows
  • Automation and Command Line Automation refinements for production build workflows
  • Building Bridges and Building a Bridge with the CLI refreshes for file-based integration workflows
Examples:
  • Extensibility:[4]
  • Building Macros:[5]
  • Automation:[6]
Build, export, and graph workflow docs
The broader workflow docs also received another pass, especially around build setup, terrain management, and graph navigation.
  • Build Options overview and tab pages
  • Resolution, Build, Tiles, Nodes, Script, Terrain, Regions, Profiles, and Commands
  • Build and Export
  • Exporting Nodes
  • Managing Graphs
  • Navigating Complex Graphs
  • Portals and Chokepoints
  • Crafting the Surface
  • Importing Terrains
  • Colorizing and Textures
Examples:
  • Build Options:[7]
  • Build and Export:[8]
  • Managing Graphs:[9]
Install, setup, and guides
We also tightened up several setup and pipeline-adjacent docs so getting started and bridge-based use cases are easier to follow.
  • Install Gaea
  • Portable Installation
  • Uninstall or Clean Install
  • Starter Guide
  • Scale and Resolution
  • Guides
  • Universal Instructions
  • Gaea2Unreal
  • Unreal
  • Troubleshooting
Examples:
  • System Requirements:[10]
  • Install Gaea:[11]
  • Gaea2Unreal:[12]
Videos and learning links
The video side also received a smaller but useful update pass with more official learning links tied back into the docs.
Updated or added pages include:
  • EasyErosion
  • Distance
  • GraphicEQ
  • IceFloe
  • Transpose
  • Terraces & FractalTerraces
Videos:[13]
Release history and quieter cleanup work
Some of the April work was less visible, but still important:
  • Release history pages were cleaned up and backfilled
  • Section index pages were refreshed across Developers, Guides, Using Gaea, and Node Reference
  • Cross-linking between related workflow pages was improved
  • Search and navigation coverage improved through stronger index coverage and updated entry pages
Basically: fewer stale entry points, better route-finding through the docs, and more current coverage for the main 2.x workflow.
What is next
There is still some April documentation work that did not make this post, and that will be folded into follow-up updates.
Expect more work around:
  • 10 additional guides
  • More node usage guidance and comparison coverage
  • More feature pages that missed the April cutoff
  • Additional workflow examples and bridge-oriented documentation
  • More official video links from Maarten
  • Continued consistency passes across newer Gaea 2.x documentation
If you come across any doc issues or gaps in theory and explination, feel free to tag me in the chat channel
Till next time
:star:
  1. ↩︎
  2. ↩︎
  3. ↩︎
  4. ↩︎
  5. ↩︎
  6. ↩︎
  7. ↩︎
  8. ↩︎
  9. ↩︎
  10. ↩︎
  11. ↩︎
  12. ↩︎
  13. ↩︎
May Docs Update
[!faq] Publishing in progress
This is a May docs update.
  • Some May documentation work may still take a little time to appear everywhere in the live docs.
  • There is process lag between writing, review, topic updates, and live docs updates, so please bear with us if a page or link updates slightly later.
May was a more focused documentation month after the larger April pass.
The main work this month was around preparing new guide material, adding more visual support to node pages and continuing selected Node Reference updates
This round covered ~100 documentation page updates, plus a larger batch of new or updated visual assets.
At a glance
Area Updated pages/files Notes
Node Reference 38 Selected node pages updated, mostly visual-direction support and embeds
Guides 18 New scenario and workflow guide pages prepared and cleaned up
Release History 40 Changelog and version history updates
Videos 3 Official node video pages updated
Using Gaea / UI 2 Focused graph workflow updates
Visual Assets 39 New node visuals and supporting media added
New guide work
A large part of May went into preparing new guide-style documentation.
These pages are aimed at practical production workflows, including planning, debugging, graph readability, build choices, terrain handoff, reusable templates, and delivery preparation.
Updated guide areas include:
  • Art-directing from reference
  • Diagnosing terrain look and shape
  • Planning scale, height, and resolution
  • Multi-purpose terrain outputs
  • Profile-driven builds
  • Resolution and tiling workflows
  • Auditing graphs before build
  • Building the right version
  • Cleaning production masks
  • Debugging macros with test nodes
  • Delivering terrain packages
  • Exploring variations safely
  • Handing off terrain intent
  • Keyboard-first workflow
  • Portable file node paths
  • Readable complex graphs
  • Reusable terrain templates
  • Source, build, and publish data
These pages are part of the wider effort to make the docs more useful for real production decisions, not just feature lookup, whether that’s an individual or a team effort.
Node Reference visual updates
Another focused pass on the Node Reference, mostly around adding or improving visual-direction assets and embeds.
Updated node areas included:
Surface 22
Simulate 12
Modify 4
Utility 2
Output 1
There is still more to come, but these will be finished in June’s update
A smaller update pass also touched official node video pages.
This includes
  • all of Maarten’s latest node ref efforts.
  • direct links from doc to community files
see more[1]
Smaller workflow and docs-system updates
A few focused workflow and docs-system updates
These included:
  • Updates around graph organisation and modifiers explanations
  • TOC / hive data updates
  • Supporting data updates for links, video entries, and generated docs structures for SEO/LLMs reading
These are less visible from the user side, but they help keep the documentation system moving cleanly as more Gaea 2 content is added.
What’s planned for June?
For June, the focus will be:
  • Continuing through the remaining May backlog
  • Backend optimisations for the documentation system
  • Adding and improving any newly added Gaea 2 content
  • More guide coverage (based on feedback)
  • More node usage guidance and visual examples of the remaining nodes
If you come across any doc issues, missing explanations, unclear theory, or workflow gaps, your feedback is welcome. Feel free to tag me in the community chat channel
Onwards to June!
:star:
  1. Videos - Gaea Documentation - QuadSpinner ↩︎
June Docs Update
This is a June docs update.
  • Some June’s documentation work may still take a little time to appear everywhere in the live docs.
June has been a month of organising and polishing the visible side of the docs, on and off. There has not been a large front-end overhaul, but we have continued adding, improving and lots of polish across the Doc site.
More importantly, the documentation for Gaea 2 is now in a much more complete place.
That does not mean every page is finished forever. (Documentation rarely works that way) However, the major gaps have been filled, and the overall experience is considerably stronger than it was at the start of this project.
Juneables?
The main focus was visual coverage:
  • New and improved images and optimisations across the documentation
  • Better visual support for existing explanations
  • Completed data around outputs for other applications
  • Continued cleanup and refinement of Gaea 2 content
  • Smaller corrections and improvements where needed
Together, these make the docs easier to follow and more useful when working inside Gaea. I have taken into consideration new and existing users, technical and visual reinforcements solo and team workflows.
Gaea 2 documentation
After a handful of months of guide work, Node Reference updates, videos, workflow content, and visual improvements, the Gaea 2 documentation is now substantially more complete.
There will always be room for another example or a clearer explanation, and we will continue responding to feedback. For now, though, we have reached a good point to keep focusing our drives into Gaea 3 and the knowledge required for its docs too!
Meanwhile, in development land…
While the documentation side is slowing for the next phase, the development team certainly has not.
The team are heads down and hard at work on Gaea 3. There is nothing more to share here just yet, but a great deal is happening behind the scenes.
As always, feedback is welcome, so if you find information missing or an area where you think you can integrate better but seemingly aren’t, let me know.
( and yes, we know both updates aren’t live just yet)
:star:
