Hi there - I’m curious how we can add a simple coastline. In the simple video below, there’s a “coast” node. This seems to no longer be present in Gaea. What’s the solution now?
/sea node is what you’re looking for
This was the later node where coastal and coast -like nodes became Unified in Gaea 1. Check out the properties and mix a couple of workflows in there, you should be able to spot them fairly easily.
