Hi!
I need to export a 6097x6097 heightmap.
Is this possible?
In the docs you state:
“Forcing a resolution:
If you want to enforce a specific resolution, you can do so manually by saving the graph up to the desired node at your desired resolution. Then you can import it to a new graph using the File node. This will upscale the file to the new final resolution.”
From this I cannot work out how I would be able to export with a custom resolution?
Best
Felix
Hey there,
It sounds like you’re using an unreal workflow and I think there’s some confusion between Unreal’s Landscape components and heightmap resolution.
Component size isn’t the same as heightmap resolution.
Unreal calculates the required heightmap dimensions from the component size and number of components.
For example, 6097 x 6097 is simply the result of using 24 x 24 components with 254 quads each. It’s not a resolution you specifically need to target.
The recommended workflow is:
- Build your terrain in Gaea at a standard resolution, such as 2048, 4096 or 8192.
- Use Gaea’s Unreal output node this normalises and converts it to a compatible heightmap resolution target, such as 2077, 4033 or 8129.
- Import into Unreal using the corresponding Landscape component configuration.
You can use the terrain definitions m per Px, to determine if you hit the resolution/“texel” density required for your project
Choose your Landscape configuration based on terrain size, detail and performance requirements. You don’t need to force Gaea to build at 6097 specifically.
Epic explains the relationship here:
You can also use the Gaea2Unreal plugin to automatically configure the landscape component ( you can still override if required).
See if this helps you out.
All the best.
EDIT I’ve replied in the scope of Gaea 2, though you did show me the docs to Gaea 1
if you are using Gaea 2 i recomend the Gaea 2 docs
