Export failing
the code is: 7B9-20260415
I have to add that I have done a couple more exports since then at 16k normal export mode so that will probably show up too.
Thank you for the diagnostic logs code. I will investigate the issue. Will it be possible to share the .terrain file facing this issue?
crowmire 4.terrain (381.7 KB) it’s essentially the same file as before but with texture masks.
