Hello, when I build my terrain I’m getting full white areas and I dont know how to solve this. First image is the built tile, second is in Gaea
Interesting…
Are you exporting EXRs? Does it persist if you export it as PNG16?
Could you kindly check if there’s anything in the Alpha channel of the output image as well?
If at any point you’re using auto level or otherwise normalising data with other nodes or modifiers like remap, this will create a scenario where you will normalise per tile, unfortunately this will give you a different range per tile instead of a uniform one shared between, as tile builds don’t have context of other tiles.
you can find out more here about tiled builds, consider hybrid build or other possible solutions.
