Hi,
To the Gaea team. I came across a tutorial you published and I am wondering why you don’t share the file associated with your tutorials so we can follow what happening and become better using the software ? is the file a secret?
Cheer
Hi,
Cheer
The project itself?
or the file nodes?
In both cases one answer is the file node, it’s not licensed to just share ( megascans asset) you can just replace this with anything mind, or get the megascans asset, but if it were shipped without the file or a different one, then someone follwoing step by step woudl still be confused and just not understand.
Another could be for tutorials like this ( step mby step) some of the goals are to make a users step by step themselves to understand why and apply the ideas themselves ( a learning process)
Finally it may be something the team want to refine to add to the examples
There could be even more reasons but these are a few logical ones.
Here is the Original File Node input
In cases where Maarten has shared files and deep learning.
Check out out his post here and his latest starter guide on YT
Hope that helps
Partially I don’t want to make it a habit of sharing each file because it can lead to more questions than answers. People will try to just make the file work rather than actually understanding and learning the techniques used.
I create rather complicated node graphs, and I’d have to revisit/improve them because to someone who’s learning and didn’t create them it probably looks like a confusing mess haha.
The idea of more examples etc. has been discussed. might take some time to refine a few terrains into simpler versions for more examples.
Regarding this it’s mostly just a time management thing. I am 1 person. I need to research ways to create terrains, then record edit and upload tutorials, test SEO stuff, record, edit, upload documentation videos, create art for thumbnails, blogs, covers. So it will likely happen in the future when time allows for it. But for now documentation and content are the priorities.
Never one person buddy, here anytime if you need to support.
yes sir
