maimum map size you can eport, thanks
Depending on what you mean by size it could be mean a number of things
Scale
Realistic scale ( using terrain definition)
- Height - 10,000m (10KM)
- Scale - 2,400,000m (2400km)
If you’re not using the terrain definition then values are arbitrary, more artistic and can represent whatever value you like
Resolution
Resolution depends on the type of export and licensing you have.
For example
If you have Gaea Pro you can export:
- 8/16k meshes
- 16k single tile height fields
- 256k tiled height fields
- 4k Unity/Unreal nodes ( render engines maximum)
For the first paid tier indie:
- 8k meshes
- 8k single tile builds
- N/A tile builds
- 4k engine builds
And the free community version is
1k limits
There are other differences and limitations you can checkout /GaeaCompare
